Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Just getting frustrated
    Jun 2012
    Baltimore, MD
    27
    Let me be frank, I haven't read through your forums in their entirely except the what we need to know so I apologize if I haven't read about the solution for my particular problem. I intend to read as much of your forums as possible these next few weeks so I can learn to care for my pool properly.
    Quick backstory: My wife and I bought a house with a pool that hadn't been opened in 2 years, the cover dry-rotted and all the leaves fell in the pool over those two years. Never owned a pool before.
    Problem history: Filter cartridge originally - the previous owner had the wrong size filter cartridge in it (too small). I bought the right size cartridge and then the pump went up. I was talked in to buying a 2 HP 2 speed pump but realized (too late) that it was too much pump for the filter to handle (too much head lifting the cartridge up and water bypassing. Drained pool, dredged leaves, fixed pump, fixed filter (bought a new DE filter yesterday).
    Here's my current specs and pictures to follow:
    FC: .5
    CC: My current kit doesn't test for this... neither does Namco (where my water was tested).
    pH: 7.2
    TA: 80
    CH: 200
    CYA: 50
    Current water color: Cloudy blue. Tried a floc (with the old filter) to no effect.
    Your assistance is greatly appreciated.
    Pool Size: 24' Round (~13,600 gallons)
    Filter Type: DE
    Pool Type: AG
    Pump Size: 2 HP Dual-speed
    Filter Flow-rate: 63GPM
    Re: Just getting frustrated
    Welcome to TFP!
    It looks like you have two different problems, low FC level associated with hazy water and paint flaking off.
    The first thing to do is to raise the FC level to shock level. That might be enough to clear up the water right there, or you may need to [shock:g718pp09]shock the pool.[/shock:g718pp09]
    The paint problem is unrelated, and not so simple to deal with.
    38,322
    Welcome
    Keep reading Pool School ... maybe a few times as there is a lot of great info there. Soon you will know more that many pool store employees.
    I agree you should probably go through the shock process since your FC is too low for your CYA level, see:
    Recommended Levels
    Chlorine CYA Chart
    However, to best control your pool, the first step should be to invest in one of the recommended test kits (see my signature for link) and while waiting for the kit, keep reading
    Jun 2012
    Baltimore, MD
    27
    Okay, reading the shock information and going to get shock now.
    Paint flaking? How do I fix this or what do I do about it?
    Going to order the TF-50 test kit (thanks for that bit of info - don't need the pH test since I can do that at work on our handheld digital pH probes).
    Filter Type: DE
    Pool Type: AG
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    I'm wondering if Jasonlion was seeing the reflection of the clouds in your photos and mistook it for paint flaking? You have an above ground pool, right?
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Jun 2012
    Baltimore, MD
    27
    Yes, it's an above-ground pool. Going out to buy shock now... I LOVE that these forums support Tapatalk!
    In the pictures please reference the area under my shadow, I tried to take the pictures of the water as much as possible but a camera can only do so much without being underwater.
    Filter Type: DE
    Pool Type: AG
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,095
    What do you call "shock"?? If it's sold in a bag stay away!
    Only get liquid chlorine or liquid bleach!! You've got an issue with algae in your pool.....needs to be killed!
    Apr 2010
    Altoona, AL
    242
    Wait... buy lots of bleach, not a store bought shock product! Considering your CYA is already 50 ppm you don't need to use anything that will make it go higher. That will cause you to use waaay more bleach to bring your water up to shock level. Consider chlorine pucks and any bagged "shock" product off limits right now.
    Jun 2012
    Baltimore, MD
    27
    The liquid shock (bleach) of course. That's all I've ever used.
    Filter Type: DE
    Pool Type: AG
    Jul 2011
    Eastern Ohio
    7,095
    Apr 2010
    Altoona, AL
    242
    Apr 2010
    Altoona, AL
    242
    Leebo, our last two posts are so similar it's almost scary! LOL
    Jul 2011
    Eastern Ohio
    7,095
    Great minds think alike.
    I'm wrong, no paint, so it can't be paint flaking. But it sure looks like that is what it is (in the first two pictures, but not the third which does look like clouds).
    38,322
    I can't see it ... I always see a guy holding his phone
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    That's probably the best looking 2 year neglected pool I've seen here! With those kind of starting numbers progress should be quick if you hit it hard with lots of bleach and make sure you stay on top of your filter pressure.
    Quote Originally Posted by RBK2001
    FC: .5
    pH: 7.2
    TA: 80
    CH: 200
    CYA: 50
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    All I see is his reflection and clouds/trees. I think you've been spending too much time in the pool house breathing in "fumes." LOL
    Jun 2012
    Baltimore, MD
    27
    Well Jesse, last year I tried fighting with dredging the leaves out in a full pool to no avail so this year I drained it down to about 1 foot of water and dredged out leaves first (9 55 gallon contractor bags worth! The old fashioned way too - syphon using the pool vacuum hose so I could vacuum while syphoning).
    I just hope that it's only algae growth and sorry about the photos but those are legitimate clouds!
    Filter Type: DE
    Pool Type: AG
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    My pool was neglected over one winter and it looked 10 times worse. Mine was green with duck sh*t and black leaves. As to the photos, I thought I was seeing cracked plaster until I read the second message about reflection and clouds.
    Follow the suggestion you get here, ignore the pool store, and read your pool school. I am a new convert and my past pains are motivating me to follow the BBB guidelines.
    -- Guy --
  20. Back To Top    #20
    Jun 2012
    Baltimore, MD
    27
    No noticeable change in clarity this morning (using the OTO test came up deep orange). I will post pictures after I get off work. I read most of pool school and will read some more this afternoon. There's information in there the pool store never dreamed of telling me.
    Question: Should I keep the pump running the whole time?
    Filter Type: DE
    Pool Type: AG
