Thread: PH rise due to SWG?
    May 2012
    Boyd, Texas
    93
    PH rise due to SWG?
    I keep hearing that SWG will cause Ph to drift up over time. How fast is "over time"? I know it depends on borates (assume 0) and TA (currently 113), I also know it varies with every pool but are we talking .5ph a week or more or less...
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    Re: PH rise due to SWG?
    That depends on several factors. In extreme cases PH can drift out of range in hours, other times days, when things are adjusted correctly weeks to months. High TA tends to cause the PH to drift more quickly. Lots of aeration also causes the PH to drift more quickly. You can stop, or at least greatly reduce, PH drift if you follow our recommended TA levels.
    May 2012
    Boyd, Texas
    93
    Yeah I plan on following recommended level. Speaking of, pool calculator says adding CYA will drop PH, will this also drop the TA level?
    Yes, but not enough for you to notice or be useful.
