Thread: dry acid for fiberglass pool?
    Hi, does anyone know if dry acid is safe to use in a fiberglass pool? Thanks in advance.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: dry acid for fiberglass pool?
    Quote Originally Posted by rainman168
    It is safe if used properly, but it needs to be thoroughly dissolved in a bucket of water before it goes in the pool. Otherwise it will settle on the bottom.
