Thread: How often should I clean my SWG?
    Jul 2011
    Surf City, California
    24
    I have a Pentair IntelliChlor Chlorine Generator. It is brand new and it has a sensor that indicates it needs cleaning but has not turned on yet. Should I trust it or do a routine clean every six months?
    25-30K Gallon Inground Pool and Spa
    DE-Filter system 60 Sq. ft
    Salt Chlorine generator
    Pebble Bottom
    Variable Speed pump
    Re: How often should I clean my SWG?
    When the check cell light goes on you should remove the cell and do a visual inspection of the cell plates. If they look clean then put it back. For regular debris stuck in the plates you can wash it out with a garden hose. Only if you see white crusty accumulations do you do an acid soak.
