Thread: Replacing Intex Cartridge Filter
    May 2012
    Omaha, NE
    14
    I am looking to replace the 1500 GPH cartridge filter pump that came with the 18'x52" AGP. I like the idea of the sand filter - not having to change out cartridges, clean them, replace them/ etc.
    I am curious if anybody has experience with the 1600 GPH Intex Sand filter vs the 2650 GPH Intex Sand filter.
    What I am mostly wanting to know is if the 1600 GPH has enough power to use the vacuum effectively. It seems with the cartridge filter that came with pool - 1500 gph, it doesn't have a lot of sucking power for the vacuum attachment. I would assume that the 2650 would have a lot more power.
    Or are there similarly priced models from other manufacturers that anybody would recommend?
    Thanks!!
    Pool: Intex AGP - Round 18' x 52"
    6981 gallon - per their documentation
    2650 GPH Sand Filter
    Intex Krystal Clear SWG
    Re: Replacing Intex Cartridge Filter
    Given the size of your pool, I strongly recommend the 2650. Not only will it vacuum better, it will also go significantly longer between backwashes/cleanings. In that price range the Intex units are difficult to beat. You can get something better for almost twice as much money, but that is a big step up and not worth it for most people.
    MtnMisty's Avatar
    Mar 2012
    Northern California
    12
    Sorry, I don't have comprative cartridge to sand filter experience, but I have to say, I love my Intex 2650!
    I sprang for the 2650 sand filter/pump for my new-to-me used 18' x 52" Intex. This is my first pool. Based on info garnered from this site, I didn't even consider using the original, inadequate cartridge filter that came with the pool. The 2650 is the only new item I bought for the set-up ... everything from the pool kit to the SWG to the solar cover came off craigslist. I figured it would be worth the investment. So far (3 weeks), so good.
    I LOVE MY 2650! Woosh. I actually put my hands up flat facing the jet and lightly swim against it! Woosh! lol
    Now, if I can just figure out how to vacuum more efficiently (the pump is totally efficient, operator is not ... she enjoys the pool so much that she goes to la-la land while vacuuming!).
    Intex 18' x 52" Ultra-frame AGP, 8200 gal(?), used
    Intex 2650 Sand filter/pump, new (happy dance!)
    Intex SWG 8110, used
    Intex Wall Mount Surface Skimmer/Vacuum, used
    Solar Cover, used and a Patch Kit, now used.
    May 2012
    Omaha, NE
    14
    Thank you both for your input. I was kind of leaning towards the bigger pump - figure it's like anything: go bigger or you'll regret it later.
    Thanks again! Great site!
    May 2009
    Youngsville NC
    395
    There is a point of diminishing returns on pump size, but the step you're considering is not it. Bigger filters are just about always favorably looked upon - bigger means it filters better for longer between cleanings.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
