Hello, and thank you in advance for any replies.
This is my first pool, I have all Pentair salt water system. I had an electrician install a GE timer on my pool (got from home depot).
The way he connected it, is to the pump only, where it turns it on and off, but not to the SWG. So when the pump is off, the SWG has the "no flow" red light on, and the other generator lights are on......
Is that the right way to connect a timer, or should the SWG also be connected to the timer, to completely turn off when the pump is off?
Thanks
Thanks
