Thread: vitamin C on pool stain
    Oct 2010
    michigan
    284
    Little section in the pool that has a stain, put some vitamin c on it and it disappeared. how long will it take for the stain to return?
    stain was there before i did a 1/3 drain twice to lower CYA levels.
    enough fresh water to keep it diluted so the stain doesn't return?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Re: vitamin C on pool stain
    It is impossible to say, as it depends on lots and lots of things. If you are worried about it, use sequestrant or replace water to get your metal level down.
    Oct 2010
    michigan
    284
    Wish i releazied i had the stain before i drained 1/3 two times,
    coulda did the vitamin C on it and then drain 1/3, woulda got some of the metal out.
    Couldn't you make a contraption with a small water pump.
    enclosed contraption with opening at the bottom and top to pump water out. put vitamin C in it, and go along the side of the people were the stain is. soon as the vitamin C disolves the stain the water would be pumped out immediatly onto the lawn.
    Oct 2010
    michigan
    284
    can i throw a patent on this seems like it would work lol
