Thread: 15x48 metal frame pool needs liner
    First time posting, hope someone can help. I have the metal frame intex pool that is in dire need of a new liner, mine has worn thin and has way too many holes to patch again. I have been searching for a line for this frame, but the ones i find cost as much as the whole pool did. I can't afford to replace it with what i know i need.
    Can one of teh overlapping liiners work and if so, how do i keep the overlapping part overlapped? I havn't seen any coping strips that fit over the metal frame. Any suggestions?
    Mar 2012
    Amarillo, Texas
    341
    Re: 15x48 metal frame pool needs liner
    I'd start checking craigslist in your local area. You might be able to pick up a cheap pool and strip the liner for next to nothing.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Take a look at this link: http://www.troublefreepool.com/insta...me-t42085.html
    mpacheco's idea is good also.
