Thread: Hayward s200 Laterals
    Is there a way to change the laterals on a hayward s200 sand filter without removing the bottom assembly. doesn't appear to be enough room to screw them out. any help would be very much appreciated.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Hayward s200 Laterals
    Welcome to tfp, wabash23
    I do not have experience with your filter, but most sand filters need the sand removed at least to replace laterals. On mine since the laterals do not fold up, I have to remove the sand an then raise the laterals up so I can access them through the top of the filter with my hand.
