Thread: Program speeds on a Hayward Ecostar VSP w/Jandy iAqualink?
    I have a Hayward Ecostar VSP pump and the Jandy iAqualink. Can I program speeds into the iAqualink web interface to run certain features at certain times, ie: filtration low speed 1750 rpm, 8am to 8pm 7 days; spa 3000 rpm; spa heat 2750 rpm (min); wtr feature 2750 rpm with the Ecostar in standard wiring or do I still need to wire relay inputs to automate these features?
    Thanks in advance for your help and input!
    Re: Program speeds on a Hayward Ecostar VSP w/Jandy iAqualin
    Welcome to TFP!
    I don't think the Jandy system knows how to talk to the EsoStar using Hawyard command language, so you need to setup the system in an external speed control via relay contacts mode. That will require several relays in the Jandy system.
