Thread: Replacement tracks?
    Replacement tracks?
    We took down a pool and some of the track pieces broke. It is made out of resin and I'm having a hard time finding "track parts" online. Do they even sell them? It is an Aqua Leader pool...probably about 13 years old.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Replacement tracks?
    Good luck, I've tried contacting Aqua Leader and gotten responses until I tell them specifics and then nothing further. I've got 2 tracks and 1 plate that I'd like to replace but I think I can get by without having to. The inside of the tracks are torn a little on the inside, I think during dis-assembly and one plate is broken. The plates are interchangeable top to bottom and I think I can make one good enough for the top.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    My husband had talked about possibly gluing the pieces together...I'm assuming that would not work with the weight of the pool that will be on it?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Not sure how yours are broken, there is a lot of weight on it. Mine, the inside support for the wall is compromised for a couple of inches, so the weight of the water will push outward on the wall holding it against the good portion of the track.
    I believe Aqua Leader is now owned by Wilbur if you have a local Aqua Leader dealer or possibly a Wilbur dealer you might be able to get parts from them. I don't have an Aqua Leader dealer close and wasn't concerned enough to look for a Wilbur dealer
    Dan D
    Thanks for the info. Our is broken in certain spots...it's like they just snapped from the cold. We were not able to put it right back up after we took it down from someone else's home and it's been sitting a couple of years and we live where it gets cold. We do have a local dealer that may be able to help us after all. We'll figure it out, hopefully!
