Results 1 to 9 of 9
Thread: Fair cost to fix a leaky pipe
    Sep 2011
    Atlanta Ga
    310
    The leak detector guys determined that there is a little leak in the suction pipe carrying water from the pool to the filter. I talked to a guy at a local pool store who said he would charge $100/hour to fix it, and that it would probably only take an hour or 2 but he could not promise anything. The pipe is only about 18 inches under ground. He said if it was a leaky joint it would be quick and easy, but if it was flexible hose that was collapsing it would he harder.
    $100/hour seems a little high, but if it is only and hour that is no big deal.
    Does this all sound fair and reasonable, or should I shop around?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Jul 2011
    Walnut Creek CA
    124
    Re: Fair cost to fix a leaky pipe
    $100 an hour seems a little high - even for the bay area here. It's basically a side job/nixer/barn job that has little to no technical aspect to it. I would have assumed $50 to $70 an hour. Digging seems like it will be the toughest part.
    Sep 2011
    Atlanta Ga
    310
    I can dig it myself. If it is simple PVC I think I can fix it myself, but I wouldn't mind paying someone who knows what they are doing to check it out. I don't want to pay $100/hour if I don't have to.
    I guess I need to be super careful when digging not to damage the pipe with the shovel. I probably need to hire someone who knows what they are doing.
    27000 gallons
    Pool built in 1971.
    Aug 2010
    Dallas, TX
    4,052
    Even if you spend an hour digging and you find it's not normal PVC, you saved $100 you'd have had to pay them.
    Sep 2011
    Atlanta Ga
    310
    My only concern is that I will hit the pipe and damage it while digging.
    27000 gallons
    Pool built in 1971.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by TomAtlanta
    Fixing shallow pipes is trivial. People dig up PVC routinely with backhoes without damaging it. Just dig slowly and watch the hole. No chopping with the spade and you'll be fine.
    Sep 2011
    Atlanta Ga
    310
    What if it is flexible hose pipe? Is there any greater danger of damaging that?
    27000 gallons
    Pool built in 1971.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I don't know... but it seems to me if you damage the damaged/leaking pipe digging down to the pipe you simply need to use a bigger patch; 2 feet of pipe/hose instead of 1 foot.
    So, the risk of damaging $2 worth of pipe is better than paying the tech $100 in labor... to save the $2 worth of pipe.
    Just my thought...
    -- Guy --
    Sep 2011
    Atlanta Ga
    310
    Just my thought...
    Yes, of course you are correct. I don't have much experience of confidence with this stuff, but of course I could figure out how to do it. I need to develop more of these skills now that I am retired.
    Thanks for stating the obvious, which for some reason was not obvious to me when I asked the question.
    27000 gallons
    Pool built in 1971.
