Results 1 to 9 of 9
Thread: Where do you dump the chemical mix after testing?
    May 2012
    Austin, TX
    140
    Another "newbie" question -
    What do you do with the mixed chems after testing levels?
    Do you dump the liquid into the pool? Throw it down the sewer drain?
    Mix yourself a cocktail (no!)
    David
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    38,301
    Re: Where do you dump the chemical mix after testing?
    Drain. Do not put it back in the pool.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    I genrally aim at the fence and pitch it-----then rinse the vials.
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    This was asked in a different subforum last week....
    throwing-k-2006-test-water-back-into-the-pool-t45068.html
    I also asked there what about dumping down into a septic system when you don't have municipal sewage. Threads get lost down through the list though as this looks to be a very active (and informative) forum. Thus, I didn't get an answer to that particular question.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    I toss mine in the grass and rinse the vial. Haven't killed any grass yet and it's been pretty much the same spot for a few years.
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Casey's Avatar
    SW PA
    10,448
    Grass.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    I have a small patch of gravel where the sprinkler controls come out of the ground. I dump it there, hoping the stuff is toxic to weeds.
    Mar 2010
    Spring, TX
    1,082
    I do all my testing inside so dump it in the sink.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Quote Originally Posted by Richard320
    This, minus the sprinkler bit.
    6000gal IG gunite // Hayward cartridge filter // rooftop solar heater // 32ppm borates
    Only two chemicals go in my pool! - bleach and muriatic acid!
