Results 1 to 15 of 15
Thread: BABB
    BABB
    Just curious. Why is it not the BABB method instead of the BBB method? After all without acid, I would suspect most of us would never have a trouble free pool.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: BABB
    I never use Borax or Baking soda. I've spoken out before that the term is confusing and misleading, but it seems to have taken hold. People often believe they need to add baking soda to a pool without testing TA or pH.
    38,520
    Re: BABB
    I cringe when I see the post from new members saying "I have bleach, borax, and baking soda!!! How much of each do I add?" with no test results.
    BBB is simple to remember and around for along time, but the method is more about understanding your pools chemistry through testing than about the specific products you use.
    30,432
    Re: BABB
    There has been much discussion about changing it but to what? Nothing seems to be short enough and, no matter what, BBB seems to stick.
    We have even had discussions about a contest for the new name...perhaps even with a few bucks involved....Do you think it wouldget much interest?
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Re: BABB
    Might be way too simple but how about the TFP method??
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    SW Indiana
    9,199
    Re: BABB
    Quote Originally Posted by ship of fools
    It would be good and simple, but probably claiming credit where it's not due.
    May 2009
    Dallas, TX
    785
    Re: BABB
    Quote Originally Posted by JohnT
    I think this forum would be better served by simply throwing out the "method" terminology entirely. All it does is confuse things. Think about it. Everything in the BBB forum would fit just as nicely under the Testing and Balancing Your Water forum. The "What is BBB?" article in Pool School could be renamed "Testing and Balancing Your Water", removing any reference to a "method", without doing harm to the info presented there.
    But if it must be retained, it should be changed to TYOP. Or alternately, TYO, for Test Y'Own. Make the check payable to Beez.
    I understand the sentimental reasons for not wanting to change, as well as the historical throwback. But honestly, the hinge to the whole thing is accurate test results. And I believe Taylor was doing that long before PF. And I would guess that bleach, borax and baking soda were almost certainly used extensively before the pool industry started marketing their "specialized" products, and "the pool store". Now the experimentation with FC & CYA that led to the "Best Guess" and Chlorine/CYA charts is different, and credit should definitely be retained there.
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Re: BABB
    I propose KICK.
    Keep It Cheap, Kids.
    Because in reality, that's what BBB is really doing.
    6000gal IG gunite // Hayward cartridge filter // rooftop solar heater // 32ppm borates
    Only two chemicals go in my pool! - bleach and muriatic acid!
    Jun 2011
    Long Beach, CA
    2,790
    Re: BABB
    I like SPC.
    Simple Pool Chemistry
    30,432
    Re: BABB
    I don't think there is any particular nostalgia for retaining "BBB". It's just that it seems to stick.
    Interesting posts, ping and Beez, they both deserve some thought.
    30,432
    Re: BABB
    Thinking a little like brainchasm, how about stealing the old military term K.I.S.S.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: BABB
    Let's see, I put borax, salt, bleach and muratic acid, in my pool. Somehow I don't think the BS-BM method will catch on. Since the methods taught here do produce a Trouble Free Pool, TFP method is truly is what it is.
    chiefwej
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    Re: BABB
    Like many here, the two main things I add are bleach and muriatic acid. I've never had any need to add the other "Bs" to my pool.
    Adding an "A" in there and making it "BABB" would make sense if you wanted the acronym to most closely spell out the most commonly used chemicals, but 'BBB' has a couple of redeeming qualities that should be noted.
    1) It's a sort of "brand" which is tied to the identity of the site.
    2) While Muriatic acid is something that many/most pool owners who frequent this site use, it is a standard pool additive of which there is no real cheaper alternative to. Bleach, borax and baking soda take the place of more expensive pool store chemicals. In a way they represent the entire point of this site.
    21,000 Gallon IG Plaster with Spillover Spa (Built in 1978) | 48 sq/ft Hayward DE Filter | 3.0 HP Pentair Variable Speed Pump | Hayward H250FDN Heater| 8 Gallon Liquidator | Taylor K-2005 | Taylor FAS-DPD Chlorine Test | Taylor "SpeedStir"
    Jul 2009
    Fort Wayne, IN
    392
    Re: BABB
    I just call it 'pool stores suck'
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    Re: BABB
    KISS Keep It Simple Stupid
    Kris
    In ground 26,000 gal. 16x36 Avg depth-6'
    sand filter used 24/7
    auto cover
    Elgin/Illinois
