Thread: Creating a known Sample of CYA
    Jan 2012
    Houston, TX
    38
    I've tried searching for this answer but my google-fu is failing me.
    I want to create a known sample of CYA concentration. That is to say, when I mix it with the reagent then put it in the viewing tube I should get 40ppm.
    For a 50ml sample how much plain water (does it have to have chlorine in it?) to stabilizer liquid do I need to add?
    Mainly I want to train my eyes so that feel more confident reading my pool's CYA levels.
    14x28 Rectangle 13,000 gallons
    Jandy CV640 cartrige filter
    IG, Diamond brite quartz finish.
    Jandy 2hp 2 speed pump
    TF-100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Creating a known Sample of CYA
    Taylor offers such samples, http://tftestkits.net/R-7065-CYA-Standa ... n-p34.html
    Making your own to a useful accuracy would probably require equipment you don't have.
    http://tftestkits.net/R-7065-CYA-Sta...ution-p34.html
    You can order a nice sample here....
    Very affordable
    http://www.circledspecialties.com
    44,000 IG Salt Pool - Pentair VF, Quad 100, Polaris 280, IC60, 400 Mater Temp
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    According to the pool calculator 1 gram of stabilizer in 5 gallons of water will give you a cya level of 52. All you need is a kitchen scale, a 5 gallon bucket and a container that can accurately measure liquid.
    Of course that assumes the accuracy of the pool calculator.
    :P
    21,000 Gallon IG Plaster with Spillover Spa (Built in 1978) | 48 sq/ft Hayward DE Filter | 3.0 HP Pentair Variable Speed Pump | Hayward H250FDN Heater| 8 Gallon Liquidator | Taylor K-2005 | Taylor FAS-DPD Chlorine Test | Taylor "SpeedStir"
    toadlife, it isn't the accuracy of the Pool Calculator that would cause a problem with your approach, it is the purity of the CYA and your ability to measure 1 gram accurately (most household scales are rather imprecise). Most people attempting to do this will get +-20%, or worse, results, which pretty much invalidates your approach for anyone not using laboratory grade equipment.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Break out your triple beam!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
