Thread: Please? Help replacing skimmer gaskets?
    LauleaHere&There's Avatar
    Aug 2010
    Rural Moloka'i, Hawai'i
    155
    I'm doing an upgrade to my little pool--putting in an appropriate-size pump, adding a solar heater, swapping some hard pipe for spa-flex so as to minimize a couple of awkward runs.
    Here are my questions:
    1. While the water level is below the skimmer and return, I intend to replace the gaskets, which are showing signs of leaking and replace the skimmer altogether. If I find rust, what's the best way to handle it?
    2. Also would like advice on how to do the above, because the lining is already cut. Or am I supposed to replace the liner when I do this, too?
    3. I have seen posts about spa-flex that don't speak very highly of it. Am I making a mistake here? Best advice, please. I do need it for at least the solar heater. And I'm trying to soften the corners of the pipe runs, because the 12' diameter is a tight circle in a small space.
    4. Any other advice?
    Thanks, everybody.
    12' round above ground pool. 3,500 gal. Vinyl liner. Waterway Supreme Hi-Flo 48 frame pump. 1.5 hp. SWG. Sand filter with Zeobrite.
    Thanks, members of Trouble Free Pool, for being so friendly and informative!
    Aug 2010
    155
    Re: Please? Help replacing skimmer gaskets?
    Bumping this up in hopes of an answer. Thanks, guys.
    22,550
    1. Depends on how bad the rust is. Anything from brushing & painting to panel replacement.
    2. While it would be better to replace the liner but if it doesn't need it, you can replace the skimmer & returns without replacing the liner.
    I can't help with the flex as I've never used it.
