Thread: How does it work?
    Sep 2011
    Plant City, Florida
    38
    How does it work?
    Installed a Liquidator on my in ground last week, but could not figure out the logistics. Both the inlet and the outlet are within a inch or two of the top, but the chlorine settles to the bottom.
    How does the chlorine get picked up? at 3 GPH there does not look like there is enough flow to mix the water and chlorine from the bottom.
    What am I missing with this system?????
    22,553
    Re: How does it work?
    The chlorine in the bottom diffuses into the water at the top. Moving water through the unit as it does, moves the higher concentration liquid out of the LQ and replacing it with water allowing the diffusion to continue.
    It continues to do this until all the higher concentrated bleach in the bottom is diffused into the lower concentrated water at the top and is pumped out.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    If you have any doubts about chlorine in the top, try testing the water. It will run you out of drops trying to clear it.
    Sep 2011
    Plant City, Florida
    38
    Thanks for the QUICK replies!
    I will leave it at 3 GPH right now and let it stabilize.
