Thread: CH and Fiberglass Slide
    Jul 2009
    Olney, MD
    218
    It occurred to me as I was cleaning my slide the other day that while my CH level being low (50) won't effect my vinyl liner, it could be slowly damaging the fiberglass slide that I generally leave running 24/7.
    Just turn off the slide, right? Well, I like to run the slide 24/7 so that it stays clean. With the chlorinated water running down, it doesn't develop the mildew (black freckles) stains it would otherwise. Sometimes I switch it from being a pool-system "return" to fresh water from the garden hose if I need to top off a little water, but generally it is fed from my pump.
    Just being cautious as they are extremely pricey to replace or even re-coat. What do you think, should I bump up my CH to fiberglass pool recommended levels?
    Thanks guys!
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    22,400
    Re: CH and Fiberglass Slide
    That's what I would do. while your vinyl liner won't care it certainly won't hurt anything either.
    Jul 2009
    Olney, MD
    218
    Thanks, it is just another cost I guess. I wasn't sure if the slides have some sort of coating that would make them less susceptible to damage from low CH.
    30,133
    I am not sure if it has ever been determined that low CH truly damages fiberglass. I have seen it discussed on here but I thought maybe the jury was still out. Did I miss something definitive?
    22,400
    I don't know if it's been decided 100% but in my mind if there's any doubt, it's not something that it hurts to add as long as you control it.
