Results 1 to 10 of 10
Thread: Cal-hypo use?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Cal-hypo use?
    We have a week long vacation scheduled for end of July in Florida. Lord knows it's gonna be HOT in Texas! My question concerns the use of cal-hypo tabs while we're gone vs. trichlor tabs. I have NEVER added any calcium to our fill water. Current tests only show it as around 60 ppm. Can these tabs be dssolved in the skimmer without any adverse effects such as the highly acidic trichlor tabs. I have a couple of floaters as well to fill. Any reason I should NOT consider cal-hypo tabs? Any one brand of them recommended over any others? Thanks!
    Aug 2010
    Dallas, TX
    4,052
    Re: Cal-hypo use?
    You shouldn't ever put any pucks in your skimmer unless your pump is running 24/7.
    Betting you'll be fine with them in floaters for a while. You can calculate how much calcium each puck will add using the pool calculator.
    Jul 2009
    Olney, MD
    218
    Re: Cal-hypo use?
    Definitely use the floater, even if you aren't running 24/7 (what if your house loses power while you are gone??). If you end up regularly leaving your pool for vacations, you might consider an offline chlorinator that you add the tabs to, you just have to stick with the cal-hypo tabs and not ever put tri-chlor in there because it could explode. You would also run the risk of going out of pH range with tri-chlor. I found out about BBB after I started using my chlorinator with tri-chlor very sad I can't switch to cal-hypo tabs without getting a replacement chlorinator...
    I also use cal-hypo sometimes to shock as I have a very low CH in my vinyl lined pool, because like you, my fill water is low in CH and I never add it otherwise.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    30,414
    Re: Cal-hypo use?
    To my knowledge, there really is no EFFECTIVE tab made of Cal Hypo. Those tabs are used for septic systems and quickly become gummy and a mess if you attempt to use them in a swimming pool.
    Jul 2009
    Olney, MD
    218
    Re: Cal-hypo use?
    What about this?
    http://pools.oversupplywarehouse.com...-50-lbs_i19747
    EDIT: I have no actual experience with these. You wouldn't want a gummy mess, so steer clear as per Dave!
    30,414
    Re: Cal-hypo use?
    From their website....
    Product Applications
    Industrial Water Treatment Pulp & Paper
    Potable Water Restaurant
    Private Water Supplies Food Safety
    Industrial Cyanide Waste Pipeline Disinfection
    Oh-oh!! Nothing about swimming pools...proceed at your own risk!
    Apr 2010
    East Texas
    9,581
    Re: Cal-hypo use?
    You're killin' all my joy duraleigh! Which just goes to show you how much I know. I just "assumed" that a 3" calhypo puck was a common item. As I said, no prior experience with it.
    Aug 2010
    Dallas, TX
    4,052
    Re: Cal-hypo use?
    I'm just hoping your pool isn't considered industrial cyanide waste! Does it smell of almonds?
    30,414
    Re: Cal-hypo use?
    The real shame is that online pool supply place that pushes it for pools...I doubt they even know any better.
    Jul 2009
    Olney, MD
    218
    Re: Cal-hypo use?
    Here it is at a fairly reputable pool supply company! That is pretty scary. Glad you chimed in Dave!
    http://www.intheswim.com/shopping/pr...d=384228&e11=Y
