Thread: Will Muriatic Acid harm solar cover
    Jun 2011
    Apple Valley, MN
    19
    Hi all,
    We keep a solar cover on our pool (just got a new one!) and I normally add muriatic acid in front of a return. Can I just pull back the cover a bit and add the acid? Or will it harm the cover?
    I've tried searching but did not find anything, so sorry if this is covered elsewhere.
    Thanks!
    25000, IG, Vinyl with Hayward S-240 series Sand Filter, Emerson 1081 Pool Motor, Hayward H250 Heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Re: Will Muriatic Acid harm solar cover
    If it's one of the bubble wrap kinds, the answer is no. They're made out of polyethylene, same stuff the disposable acid jugs are made out out of.
    Jun 2011
    Apple Valley, MN
    19
    Ha - I guess I never thought of that! Thank you!
