Thread: Raypak Versa Plus and Intex
    Jul 2011
    Webster,Wi
    62
    I was given a Raypak VP from a friend that also gave up their pool. I am having a hard time figuring out how to get the heater fittings converted to fit the Intex pool but my main ? is the flow that comes out from the heater needs hi temp pipe but do I need to change the plungger valve that came with the pool?
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Raypak Versa Plus and Intex
    It really only needs the CPVC for the first foot or so. The water won't be hot enough to damage pipe, but the pipe that's really close to the heater could get pretty hot from the radiant heat.
