Thread: 26' intex above ground/ what size pump and filter to go with
    Jun 2012
    Joplin Missouri
    45
    Hello. so glad I found this site. We just ordered the 26' intex pool. We are very excited. We are also brand new to the pool thing. We want to start out right. We have read pool school. My question is, what would be an adequate pump and filter for the 26'ER? From what we have read the one it comes with will not do the job. We don't know what kind of filter to go with either. Any advice would be great! Thank you in advance!
    28ft AG Doughboy Autumn Breeze, 1.5hp DB Powerline XP 1 pump, DB Sand Filter MM 1900 (19inch), Doughzone Generator (ozone purification), TF-100 test kit.
    Re: 26' intex above ground/ what size pump and filter to go
    Get a two speed pump. They can save a significant amount on electricity. Also, look for the largest filter you can afford and have room for. Larger filters can go longer between backwashes/cleanings.
    Jun 2012
    Joplin Missouri
    45
    Thank you! I will start looking around for something like that.
    Jun 2012
    Joplin Missouri
    45
    I've been searching through pumps and sand filters. Do you have a pump that you would recommend? As far as a 2 speed goes? Thank you.
    22,539
    I like the Pentair Dynamo 1 hp 2-speed and a SD-60 Sand Dollar filter. Of course that's what I have and it works great for me.
    Really though any of the 1 hp 2-speed aboveground pumps and a sand filter that holds about 250 lbs of sand will be a great fit. Even the Intex 2650 pump/sand filter combo would work. It's a little small for that size pool but it would work.
    Jun 2012
    Joplin Missouri
    45
    Thank you! I will look into that. Thanks again for your help!
