Results 1 to 7 of 7
Thread: intex saltwater revision
    Got my ultra frame 18*48 setup put an in wall skimmer on it and an intex 2650 sand pump (will post some pics soon ) and want to add a saltwater system.
    Question I have is what is the newest model out?
    I see them with different letters on the end which means a different revision just wondering which is the latest out the intex website is sorry for any info.
    30x14 vinyl 12,500 gal irregular,progrid DE filter, 1 hp hayward pump, 200k btu heater natural gas,aquarite SWG. live in NYC
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: intex saltwater revision
    Actually, the older models are better for the Intex SWG's. I'm not up on the part numbers but you can tell by the faceplate. I have the 2 button one which is the older model. The newer one has more buttons and has a feature that adds copper and it puts out less chlorine than the older model. Some have unplugged the copper feature because it's not good to add that to the water. The one good feature to the new model is it doesn't lose it's settings when it loses power if memory serves me plus it has GFCI built in at least on the model ending in "G".
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    I just installed a unit but have not turned it on as I am letting the salt mix, your saying don't use the copper function? What is the pro/con of it?
    Aug 2010
    Dallas, TX
    4,052
    The copper system adds copper to your water, which can cause copper staining in the pool and green hair on your people.
    Thanks RobbieH, any idea where/how to disable this on the 2012 model. From the sounds of it I don't want it.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I think some people have unplugged that part or maybe removed it and capped off the hole.
    Mike
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Just unscrew the retaining ring and unplug the connector on the copper bar.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
