Thread: Low Salt reading with a twist
    Jun 2012
    Florida
    3
    I have lived through the slow deterioration of a T-15 cell gradually showing low salt. However this time it is doing something different.
    - The instant salt reading will alternate between restarts or resets. It will read low (-2100) and then regular (-3400) every other time. If it reads -2100, I can turn off the pump, restart the pump, and it will read -3400. If I turn off the pump and restart the pump again, it will read -2100 again. It will alternate between the two readings ever single time I restart or reset the instant salt reading. It took me a while to find this pattern. I won't go into the whole thing, but it has come down to this being the issue.
    When it reads -2100, it will generate at around 4.5 amps at 100% if I have the average salt reading around 3000. (resetting until it gets there). When it reads -3400, it will generate at the proper amperage of about 6.75 at 100%.
    Has anybody come across this issue or have some further troubleshooting ideas? I just found this pattern today and thought I would get it on here for discussion. I will try to get a friends T-cell sometime this week to see if it also does this to narrow it down to either the cell or control panel.
    Thanks
    P.S. Just to note:
    I have cleaned it to visual inspection of a clean sensor inside the cell.
    Chlorine readings at the jets confirm generation.
    This is a 1.4 version
    Plug contacts appear clean and in good condition.
    Re: Low Salt reading with a twist
    Your cell is "half" worn out. The plates are coated on both sides, but only one side of the coating is used in each "direction"/polarity. The cell switches direction each time you cycle it. Apparently, your plates are worn out on only one side (for the moment), thus the strange reading.
    Jun 2012
    Florida
    3
    Thanks for explanation. My vast searching couldn't find this issue brought up before. It looks like it's time for a new cell.
