Results 1 to 20 of 20
Thread: My 16x48 ultra frame up and ready to go!!
    I finally have everything finished for the summer. I've added solar heater this year. I' ve made my version of Solar Cover saddles, it use to be a pain to take solar cover off and leave it on the grass because when you went to put it back on all that debris that got stuck to the cover would end up in my clean pool. I got some 3/4 pvc pipe and fittings and made my version of a solar holder. I've upgraded pump and filter, added through the wall skimmer and water feature. I added (Skim-it) as well, helps keep the pool cleaner, actually works. I hope you like, alot of hard work and alot of weekends goes into setting these up. It's all in the prep work, as all of us intex owners know. It keeps the kids happy on those hot summer days. I'm very happy with the Ultra Frame, I had an easy set for one summer and got rid of it, I'll have this til I decide to go with something more permanent.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Re: My 16x48 ultra frame up and ready to go!!
    Love your solar cover saddles! I never would have thought of that...
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Aug 2011
    Virginia Beach
    295
    I really like your idea- thanks for sharing it! How many holders does it take, and what size pool do you have?
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Oct 2011
    New Caney, Texas
    414
    I like it
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    how are your PVC hangers attached? great idea and looks great!
    phil
    24' Round Above Ground, Metal by SOLEX
    Heat Pump, Focus Temp INSTAMAHK 80
    Hayward S-180T Sand Filter
    Hayward Ultra Pro LX Pump
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Quote Originally Posted by PhilGillis
    phil
    I'm wanting to know this as well. That's a great cost effective idea.
    I planned on trying to attach metal hooks with magnets around the pool to hold a skimmer net and the vacuum hose stuff, but figure that wouldn't work with a solar cover. I suppose it wouldn't be too bad to drill and tap a few holes here and there on the supports to attach hooks unless there's a less "destructive" and permanent way of attaching things.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    The cover saddle rocks!!! Can we get some close up shots of it... that is as long as you're willing to share
    5K gal (16' round), vinyl UltraFrame AGP, stock cartridge intex filter/pump
    using(learning) TF-100 test kit with BBB method
    May 2012
    159
    I see the attachment method now looking at the 2nd pic. Just zipped tied on to the pole.
    Mike
    TF-100 test kit
    Quote Originally Posted by mrodgers
    Thanks I see that as well. Didn't catch it before. Great idea.
    I was playing with the idea of using hose clamps at first, I thought it would remove the finish off the legs after awhile and start to rust. I don't want that. I decided to drill 3 holes in the pvc, and ran 14" zipties through and around the leg, I pulled them very tight and they are working just fine. The pool comes down in Sept on my vacation so the zipties will make it easy for them to come off.
    ahhh I see now that you guys have pointed it out.
    Still just a great idea!
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    What a great idea for the pool cover saddle!
    We are going to borrow (ahem, steal) that idea!
    Can you share the dimensions of the PVC pipe, if you have them handy?
    BTW, what type of thru wall skimmer did you install?
    Cheers,
    Liz
    Northern California Inground pool 14' by 30'
    Diamond Brite Quartz Medium Grey Plaster - Islands Sapphire Breeze Tile Border
    Jules Bright Cobalt Blue Blend Tile Bench fountain sheer waterfall descent
    Pentair Intelliflo Variable Speed Pump - Pentair CLean & CLear PLus Cartridge Filter - Kreepy Krauly Legend - mTF-100 Test Kit - Swimmers: Twins (Boy/Girl) 16 yrs old
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Very nice setup, and a really great idea on the hangers.
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    MtnMisty's Avatar
    Mar 2012
    Northern California
    12
    Ewww, you should have patented those PVC solar cover saddles when you had a chance ... I'm stealing the idea, too!
    Thanks for sharing! What a great idea!
    Intex 18' x 52" Ultra-frame AGP, 8200 gal(?), used
    Intex 2650 Sand filter/pump, new (happy dance!)
    Intex SWG 8110, used
    Intex Wall Mount Surface Skimmer/Vacuum, used
    Solar Cover, used and a Patch Kit, now used.
    May 2012
    Illinois
    16
    Would it be possible to get a list of the materials you used and instructions on how to do this? My husband is not very adept needless to say with tools and this looks like something I could do!
    Chris
    Intex Ultra Frame 16' x 4', 5000 Gallon
    NY
    27
    Quote Originally Posted by lamboman316
    Can I ask you about your heating system? Are you happy with it? Which one are you using?
    thanks
    Intex above ground Rect UltraFrame 12x24x52, 8500gal. Krystal Clear Sand Filter Pump 14". Intex SWG.
    NY
    27
    Hi Everyone,
    I just want to share my solar cover holders, that was inspired by Lamboman316. It's working very well! Easy to fold and unfold.
    [attachment=2:18c8p29h]solarcoverholders1.jpg[/attachment:18c8p29h]
    [attachment=1:18c8p29h]solarcoverholders2.jpg[/attachment:18c8p29h]
    [attachment=0:18c8p29h]solarcoverholders4.jpg[/attachment:18c8p29h]
    Nice! This is going on the Honey-Do List.
    Intex Ultra Frame 18'x52"
    Intex 2650 Sand Pump
    Krystal Klear SWG
    poolsam's Avatar
    Jun 2014
    Bangor, maine
    66
    I know this is an old thread. How are these solar panel holders working.
    I am surprised that you could simply zip tie them to the pole and not have them drop down.
  20. Back To Top    #20
    Jun 2016
    Pittsburgh, pa
    367
    Quote Originally Posted by lamboman316 View Post
    Curious how this is holding up as well, are those 0.75" or 1.5" pvc pipes, 60 degree, 45 and 90 bends?. Also curious how much of a boost those solar panels give you in early season (ie: does 50s water become 70 etc) and which brand and do you use an actuator with them?
    Thanks
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
