Results 1 to 9 of 9
Thread: Friend has SWG and does nothing else chemical wise
    Oct 2010
    michigan
    284
    Friend has SWG and does nothing else chemical wise. Takes apart every year and puts back up.
    What is going to happen?
    Cya would be 0 for 5 month
    So what will happen with 0 CYA?
    Tells me the SWG generates enough chlorine to keep it at right level
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Re: Friend has SWG and does nothing else chemical wise
    It has a lot to do with how large the SWG is, how long they run their pump, and how far off the PH drifts.
    If the PH drifts too far (quite far), chlorine becomes much less effective and it is over. If the pump doesn't run enough or the SWG is too small it is also over. But with enough run time and a large enough SWG and some luck on the PH they could go for quite a while. Of course the SWG will wear out much more quickly than it otherwise would because it will need to run much longer.
    Don't mix up luck with things actually working.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    That's gonna work just great----------right up until it doesn't!
    Oct 2010
    michigan
    284
    i know nothing about SWG, is there a life span on a SWG? i have no idea what one even looks like it. lol
    little research looks like a SWG lasts 3-5 years/10000 hours. so no stabilzer he has to be running it more, and the lifespan is going to be shorter/
    38,305
    Yup.
    And if the pH drifts up ... which it will unless the TA is very low ... it will be very uncomfortable for eyes and skin to swim in.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    May 2012
    charlotte n.c
    28
    can i jump in?
    just got my pool up and running for the first time yesterday! can i just ask what you guys are talking about? i thought i did my homework but im learning very quickly im not prepareed at all to take care of a pool. it sounds like just a swg isnt enough , can i ask what else should he/her should be doing?
    INTEX 14' X 4'
    1000 GPH PUMP
    SWG
    taylor K-2006 K-1766
    SKOOBA VAC
    solodare, read the article on balancing your water for use with a SWG in Pool School.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by solodare
    can i jump in?
    CYA level would be first on the list. Lack of CYA can cause chlorine to drop during the day and overworks the SWCG. pH would be next. Check out ABC's of Pool Water Chemistry and Water Balance for SWCGs
    for more info.
    May 2012
    charlotte n.c
    28
    lmao! okay thanks for not killing me guys! btw ill be in pool school for the next week or two if any one needs me. is there any emergency things i should be doing until i get up to speed? i filled the pool with city water added salt and im currently waiting for it to desolve before turnning the swg on should be turnning it on tonight when i get home from work. thanks so much.
    INTEX 14' X 4'
    1000 GPH PUMP
    SWG
    SKOOBA VAC
