Thread: DE filer pressure going down???
    When I started up the pool, my DE filter was reading a pressure of 7 psi. That was when the pool was dirty after pulling the cover off. After filtering the pool, then attaching the Zodiac pressure vacuum and cleaning up the debris on the floor of the pool, the pressure when DOWN to 5 psi Now, five days later, the pressure is 4 psi. What the heck is going on? Could it be I need more DE in the filter? I expected the pressure to go UP after filtering all the dirt from the pool (it wasn't that dirty, but still). I also notice that the vacumm isn't working as well now either.
    Help!!!!
    Kelleyaynn
    21,000 gallon (+ or -) in-ground plaster pool with Nautilus DE filter, 1 hp pump, and Zodiac G4 automatic vacuum.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: DE filer pressure going down???
    1) Check the valves, in case you didn't put them back after vacuuming
    2) You might have a clog in the suction side. Less water in means less water out, which means lower pressure. Start with the pump strainer. You might try probing up inside for a clogged impeller.
    3) If that all comes back negative, report back with an update.
    I can't get the pump lid to budge. Any thing I should do before I try to open the pump lid (besides turning off the pump)?
    Kelleyaynn
    Richard320's Avatar
    Jan 2010
    19,052
    Quote Originally Posted by Kelleyaynn
    I usually have to tap on the ears of mine with a mallet or a block of wood to loosen it.
    Block of wood didn't work. I have a rubber mallet at school. It also started raining, so I think I'll have to wait until tomorrow to get this straightened out.
    Kelleyaynn
    Apr 2012
    Southampton, PA
    44
    Can the pressure gauge be broken?
    32/33?k gallon IGP
    Concrete? white plaster
    pump Pentair WhisperFlo, 1HP
    filter Pentair Clean&Clear Plus Cartridge 520 sq. ft.
    robot Dolphin Deluxe 4
