Thread: I need something clarified
    For mustard algae you shock normally and after you pass the oclt and have less than .5 cc you raise it to mustard shock level. Is this correct?
    18' x 36' saltwater inground vinyl pool
    Re: I need something clarified
    Yes, that is right. After a normal shock there will not be any visible sign of mustard algae, but it is actually still there. The an extra 24 hours at exra high shock level will get the last hidden bits of it.
    Thanks. One other question. I passed and went to mustard shock level. Rechecked a few hours later and cc's were 1.5. Is that normal?
    No, it is unusual to see CC at that point. Check the CC again when the 24 hours are up and if there is still CC > 0.5 you will need to continue shocking (though you can go back down to normal shock level at that point).
