Results 1 to 11 of 11
Thread: at 0 cya using trichlor to increase cya levels
    Jun 2011
    Lakewood, NJ
    62
    I've been shocking for 2 days now, I've tested CYA 3 times and it's at 0.
    I've only been using 6% bleach, I have huge bucket full of trichlor pucks that I would like to get rid of. We bought it for last years pool season and never used any since I was using the BBB method with great success. Thanks to you all!!!!
    How do you recommend raising the CYA level?
    Should I buy stabilizer?
    Should I add trichlor pucks, and if so is there any way to introduce it to the pool quickly, perhaps by grinding it, or dropping it into the pool?
    Or use 1 puck weekly in the feeder and use lots of bleach to compensate for the low CYA level?
    Which idea is the safest?
    Hannah
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    5) Hayward pro-grid 2420, 1 hp, 96 gpm
    Also have Dolphin diagnostic 2001
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: at 0 cya using trichlor to increase cya levels
    I think I'd buy stabilizer to get CYA to 30, and load the puck feeder as full as it will get to finish the job.
    Mar 2012
    Amarillo, Texas
    341
    Personally, I'd sell the tablets on craigslist or some other forum and go buy some stabilizer and continue using the BBB method.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Save those high dollar pucks for weekends away or vacation. A 4 lb bottle of CYA granular should be enough to do you. Good old HTH from Walmart is good.
    Jun 2011
    Lakewood, NJ
    62
    Thanks, I placed 4lb cya in a sock this morning, so far none has registered in a cya test.
    I left it hanging in the pool in a sock, not near the skimmer or a return, is that ok?
    Also, day 3 shocking and the water doesn't seem to be improving, since yesterday,it's the same cloudy, and is consuming huge amounts of chlorine, I went thru at least 15 gallons today of 6% bleach.
    Here's the process:
    after opening the pool, I spent the day lowering the ph to 7.6
    CH=100
    TA= 110
    FC=0
    we brushed, took out all the leaves and algae that we could scoop up with the net, and sent in the dolphin too.
    this eves numbers
    FC 5
    CC 1.5 (gone up, it has been .5 or 1 for 2 days)
    TA 70
    it's been raining all day here and some of yesterday too. I've been adding bleach about 5 times a day and brushing twice a day, should I continue to shock or should I address the TA levels,
    unfortunately I've misplaced my pH reagent so Leslies test today showed 7.6 pH, and their reagent is not compatible with the TFT kit. So i don't know what the pH is right now.
    What to do?
    My husband is not happy about the rapid bleach consumption, he thinks t here's something wrong, I told him it's normal. Is it?
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    38,235
    Move the sock to in front of a return and then squeeze it everytime you walk by to help it dissolve.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Mar 2012
    Amarillo, Texas
    341
    You're doing fine. And probably the 6% bleach your using is not a true gallon. They seem to be selling 96 ounce bottles in place of a true gallon.
    18'x48" AG
    Hard Plumbed
    Jun 2011
    Lakewood, NJ
    62
    it's 128 oz, from stop & shop,
    anyone with experience using their generic brand, GUARANTEED VALUE?
    so its normal, my husband just went out to buy some more,
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    Richard320's Avatar
    Jan 2010
    18,966
    Quote Originally Posted by Hannah M
    I'm not familiar with that one, but the Iris bleach my wife bought for laundry from Smart & Final is only 3%....no wonder it's cheaper!
    Jun 2011
    Lakewood, NJ
    62
    it's 6%, customer service at Stop & Shop called the company while I was there, and they confirmed that it is 6%
    1) 22,000 gallons
    2) DE filter
    3) IG
    4) vinyl
    22,537
    Don't test the CYA again for a week. Assume it's in there and raise your shock level to match.
    Keep shocking. It's normal to use a lot of bleach in the beginning of a pool opening. Take a look at some of the threads with the pics of bleach bottles used during shocking. You'll see dozens and dozens of bleach bottles.
