Thread: Got Test Kit, 1st readings - advice
    Good day,
    We are back from vacation - pool is crystal clear , have my TF100 test kit ( 1st time using it ):
    Any advice - please:
    FC - 19.0 - added bleach almost 3 weeks ago ( 4 , 182 oz jugs 6% ) - strange to me how it can still be so high, direct sunlight all day
    CC- 0
    TA - 170 - alittle high
    PH - 7.8
    cya - 100 - using the closes line in the cya tube
    CH - 280
    Pool is very clear...
    thanks so much,
    -chris
    30,000 IG, sand filter, 1 3/4hp super pump. 2 Skimmer, 1 bottom drain. Hayward 400K Heater, Polaris 9300 Sport..
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Got Test Kit, 1st readings - advice
    Try the CYA test again using 50/50 pool water and tap water; test that and double the reading. You may have 120 or 150 or even higher CYA. Then see if FC is still too high for your CYA level.
    Thanks Richard, I will do that, have one of my's son's friends bday party to attend - I will post results later...Thank You~!
