Thread: AGP electrical question. Stranded vs solid THHN #12
    May 2012
    Endicott NY
    87
    I have a electrical question, does anyone know if one is better to use than the other? I have a 50 foot run and getting ready to pull it through the conduit, but have not bought the wire yet. Can I use either one? I know stranded is easier to pull, but that is not an issue. Any do's or dont's? I will be pulling 12 g THHN/THWN
    George
    21 10500 gal AGP 52' sides, haward 3/4 hp xl pump and earth filter ec50
    Using the bbb method. Tf-100 kit. My first pool so learning in progress!
    22,551
    Re: AGP electrical question. Stranded vs solid THHN #12
    I would personally use stranded, but it really doesn't make a difference. Either will work fine.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You should always use stranded when connecting to vibration sources like motors, generators, etc.
    May 2012
    Endicott NY
    87
    There should be no vibration, It does not get connected directly to the motor.
    Geo
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    If you are running a supply line to a service panel, then you should use solid, and I would recommend going with #10 instead.
    You get a voltage drop over distance, and 50' is not a short span, and if you are going underground with your conduit then there will be even more loss.
    #12 will work, but if you ever decide to add other loads, or increase motor size, ect. ect, then pulling heavier wire now will save you down the road.
    Stranded wire from the breaker/service panel to the equipment will be fine, just make sure you size your wire properly.
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
