Thread: Cya in the skimmer
    Jul 2008
    Seacoast, NH
    250
    Cya in the skimmer
    Can someone remind me how long I need to run the filter after putting cya in the skimmer? Not using the sock method because it is pouring, has been for 2 days and will will be for another 2. Don't want to spend the time outside to set the sock up.
    Thanks
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Cya in the skimmer
    Put it in a knee high panty hose.........tie it up...........chunk in skimmer with pump running till it dissolves. I'd probably wait if you're gonna have to pump out a lot of rain water first.
    Jul 2008
    Seacoast, NH
    250
    Good idea on both points.
    1.5 HP Pump
    30,419
    woodyp,
    I think op has already put it in the skimmer or is about to and doesn't intend to use the sock method.
    Deb,
    It will dissolve on it's own over time. Run your pump as you normally would but don't backwash/clean your filter for a week.
