Thread: Backwash valve leaking
    I have a Hayward push-pull backwash valve that is leaking slowly from the top. Can these normally be fixed with new O-rings, or should I just replace the valve?
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Backwash valve leaking
    How corroded does it look? If the outside looks scaly and pitted, the inside will look worse.
    If it's in good shape, a set of O-rings and a generous coating of pool lube on everything should fix it.
    Except for the leak, it looks fine. I'll try the O-rings first.
    Thanks
