Results 1 to 19 of 19
Thread: 1st test results - really need your help
    May 2012
    Austin, TX
    140
    Hello:
    I a new pool owner trying to get things under control. The pool was filled 10 days ago. The pool store recommended 5 x 2" pucks in a floater and 2 x 2" pucks in the skimmer (I know - no more tabs) and the pool service company did the chemicals a few days ago and said I could "shock" with 4 bottles of chlorox (which I did). I read at pool school, ordered the TF-100 test kit, and got it yesterday, trying to figure all this out - here are the results:
    FC: 10
    CC: 0
    TC: 10
    pH: 7.2
    TA:70
    CH: 110
    CYA: 0 (I did the test twice - patiently - not sure if I did it correctly)
    Questions:
    1. Should I follow the targets on the pool calculator?
    2. Should I pull the tabs out of the pool?
    3. Should I.....well.......what should I do??
    4. Can I swim in my pool or is it dangerous at these levels?
    The pool is cloudy and greenish - very ugly - really need some help!!!
    Thanks in advance for any suggestions!!!
    David
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    Apr 2011
    Lynchburg VA
    393
    Re: 1st test results - really need your help
    Surprised no one has responded yet...it's been almost 8 minutes. Yes, I would follow the targets on the pool calculator but you need to get some CYA in your water if it is at 0. You are going to have to go through the shocking process so I would not raise CYA to much over 30 until you are done shocking. You can use the pool tabs to raise your CYA but I would head to the store and purchase some to get it up a little quicker. There is a good "how to" on doing the CYA test that I will try to locate and post for you.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    The # of pucks you've added would work out to a CYA of only around 20 which may not register on the test-especially if they haven't fully dissolved yet. Are they trichlor pucks? If it's cliudy and greenish, you know you should shock following pool school. The rest of your numbers look good for now.
    I was watchin' Aliens!...........gimmee a break on the 8 minutes!
    Apr 2011
    Lynchburg VA
    393
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    This might help a little with the test....
    Pool School
    Pool Calculator
    Test Kits
    Apr 2011
    Lynchburg VA
    393
    It's just unusual for a question to go so long unanswered! Aliens is a good movie!
    Pool School
    Pool Calculator
    Test Kits
    May 2012
    Austin, TX
    140
    Quote Originally Posted by woodyp
    This time 8 minutes works for me - but I expect my free advice quicker next time
    I double checked - it is actually 3" Chlorine tabs - Step 2: Sanitizer - from Leslie's. Sorry bout that.
    One 1 of the tabs is slightly dissolved - the other six of of them are intact.
    30,432
    Drockfresh,
    Have you told us what your pool water looks like?? Clear? CLoudy?
    (I was taking my seasoned citizens nap and couldn't post 'til now )
    Apr 2011
    Lynchburg VA
    393
    He said it was "pool is cloudy and greenish - very ugly - really need some help!!!
    Pool School
    Pool Calculator
    Test Kits
    30,432
    I see it now. Sorry, I skimmed past it.
    May 2012
    Austin, TX
    140
    Drockfresh,
    Dave - no napping today - this is important stuff
    My wife is gonna start asking why I broke the swimming pool
    The water is green and cloudy - it was clear a few days ago
    May 2012
    Austin, TX
    140
    I am ready to shock - a few questions:
    1. With a CYA reading of 0 - What is my FC target?
    2. Should I add baking soda and borax based on pool calculator - or just focus on the chlorine.
    Thanks guys!!!
    1) Shock level is 10 when CYA is zero. You should raise CYA to 30 as soon as possible. Shocking is much easier with some CYA in the water.
    2) All of your other levels are fine for now. Don't worry about them until you have taken care of the algae.
    May 2012
    Austin, TX
    140
    How do I quickly raise my CYA? I have the 3" pucks dissolving - but that's it - is there something I can get from the pool store to raise it up quickly?
    30,432
    Go to HD, Lowe's Pool Store, Walmart and buy it. It may be called stabilizer or conditioner but look for CYA or Cyanuric acid on the ingredients....it's all the same stuff.
    Mar 2012
    Amarillo, Texas
    341
    Go buy some stabilizer with the highest CYA percentage. They sell it at Walmart or the pool store.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    May 2012
    Austin, TX
    140
    I am done shocking and the pool looks great - Thanks all for the help!
    Here are the numbers:
    FC = 4
    CC = >0.5
    CYA = 40
    TA = 90
    CH = 120
    What do you think of these stats?
    David
    PS - Loving the pool - Here's a pic (not sure how to rotate the picture but you get the idea :
    30,432
    You don't report pH but, if it's in the 7's, your numbers look as good as your pool water.
    May 2012
    Austin, TX
    140
    PH = 7.2
    Ok - so I read about the daily pool maintenance - but not sure what to do other cleaning the pool and adding chlorine.
    This is my plan:
    1. Check FC daily - add chlorine daily to keep at 4PPM
    2. Check the PH daily -> Do I have do anything with Baking soda or Borax?
    David
    30,432
    Yes. While consuming an adult beverage by your beautiful pool, you are assigned to read "The ABC's of Pool Water Chemistry" up in Pool School. In that article (among other good information) you will find out why you don't currently need those two items.
