Thread: Raypak 406a burner issue
    Purchased Raypak 406A Heater(millivolt) in 2008. Last year we had the local shop work on it to repair a cracked weld to fix the front left burner bracket.
    This year when trying to fire it up, we had a flame out the left side that popped the thermal fuse, as that is where the flame went to. Since we have a pine
    tree that is too close, we pulled it apart to clean out the junk, and make sure the air flow is good. There was some debris on the heat exchanger, which has now been
    cleaned off. When pulling the burner to make sure that was clean, we noticed that the 4 nuts/bolts that hold the burner in place to the bracket was only finger tight, so
    it possibly shifted. When we pulled the burner out, that since new, only the back half of the burners are lighting, and that the front of the burner rails are clean and shiny
    except for one rail which lights. My question is, is this normal, and has anyone else experienced this?
    [attachment=1:2mo0k8lj]photo (1).JPG[/attachment:2mo0k8lj][attachment=0:2mo0k8lj]photo (2).JPG[/attachment:2mo0k8lj]
    Re: Raypak 406a burner issue
    I found a dead spider with web in the last burner tube so that should be my flame out the side. I still wonder about uneven burn on the burners. What I didn't say was that I'm in Colorado so I'm at 6,700 feet.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    So you're saying that when the unit is lit, and you look at the burners while burning, there is no flame on the front portion of the all burners?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
