Results 1 to 9 of 9
Thread: TA is 250
    TA is 250
    TA is 250 and cloudy water and everything else in check so I am assuming this is the cause.. How much Muratic acid should I add to lower to acceptable levels?
    21" Round Cornelius above ground pool, 2 hp 2 Speed laser pump, 400lb sand filter, 25 mil Virgin Vinyl Liner
    30,401
    Re: TA is 250
    Everything else "in check" is not helpful...TA is typically not the cause of your cloudiness. If you will post a full set of test results, we can begin helping.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Re: TA is 250
    No magic bullet. It's gonna take some time. What is your PH? Lower PH to 7.2 and as it rises back to 7.8-----------keep lowering back down to 7.2 to gradually reduce TA. See the pool calculator to see how much to add.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: TA is 250
    My TA always starts out around 325 and I've never had cloudy water. I'd be surprised if this was your cause.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Re: TA is 250
    FC 13.5
    CYA 60
    Also we have some scaling on the walls, but had it last year too and still got it clear.
    Re: TA is 250
    Do you know your CH level? What about PH?
    Re: TA is 250
    ph 7.5
    CH 150
    Re: TA is 250
    If the cloudiness is caused by calcium clouding (the only possible cause that might have anything to do with TA) it will go away if you lower the PH to 7.2.
    Re: TA is 250
    Lowered the PH to 7.2 for two days now and cloudiness got a little better. I started aerating tonight with the filter on high and inlet pointed up.
