Thread: shock n swim to chlorinate pool if my calcium is low?
    Oct 2010
    michigan
    284
    shock n swim(Cal-hypo) to chlorinate pool if my calcium is low? instead of bleach
    would use it to add chlorine and not shocking it.
    http://www.walmart.com/ip/HTH-Super-Sho ... ifications
    would there be any other side effects besides raising calcium? which I need to raise some.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,090
    Re: shock n swim to chlorinate pool if my calcium is low?
    Watch as some of the HTH items also have copper in them. Other than that you're fine.
    30,421
    Calcium is the only side effect. Go for it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    You have it figured out!
    BBB is about using what's appropriate, in the appropriate amounts, knowing the possible side effects.
    Use it. Pool Calculator can crunch the numbers for you under "Effects of adding chemicals" so you'll know how much you can safely use. If it's okay to use 12 pounds and keep CH in range, no point buying 20 pounds. But if I could get away with it, I sure would. Easier to store, easier to carry, long shelf life.
