The levels from this morning look fine to me ... no really need to mess with anything.
FC is a little higher than required.
Using the pool calculator, the CSI is a little on the negative side, so that should help prevent any additional scale if that is in fact what is on the walls.
Since you have a SWG, you could raise the CYA a bit if your pool gets a lot of sun.
The SWG will tend to make the pH rise. Lowering your TA could help with that some. But, if you do that, raising your CH closer to 300ppm would prevent CSI from getting too negative.
Is there something that you are currently worried about?
