Results 1 to 10 of 10
Thread: In ground pool with no main drain
    Jun 2012
    Austin, TX
    97
    Our PB wants to sell us an upgrade to a pool without a main drain.
    It consists of a Hayward ecostar variable speed pump, low returns for better circulation, and 2 skimmers. This will be for an inground pool approximately 33 x 17.
    Is this a good option? Can you really achieve enough circulation without a main drain? Any advice would be appreciated.
    32x15 freeform gunite pool (approx 15,000 gallons) with a 7x7 raised spa with 2 spillovers - tanning ledge with 2 bubblers - All Hayward Equipment - ARQ15 SWCG - 400btu heater, 60sq ft DE filter - 2HP EcoStar VS pump - Oklahoma flagstone coping - MasterTile MASMIX 3 1x1 - Sundek - Crystal Stones Smooth Caribbean Blue - TF-100 - Doheny's Discovery Robot
    Re: In ground pool with no main drain
    For a fairly standard pool without any waterfalls or other major water features, a variable speed pump is only worth it if your electric rates are $0.20/kwh or higher. Otherwise you will never pay back the extra up front costs. With low electric rates a two speed pump is a much better choice.
    While it can be really nice to have a main drain sometimes, it certainly isn't required and does not affect the pump choice.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    I have a 38 x 18 inground rectangular pool. One speed pump, one skimmer, 2 return, no main drain. I have NO problem with adequate circulation. I would add that I tend to use pump >8 hrs day.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    Jun 2012
    Austin, TX
    97
    Thanks for the information. I'm not as worried about the energy savings as I am with the noise. I was told the variable speed pumps are much quieter. Is that true?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    My pool also has only one skimmer and two returns, and while it works, there are many times I wish it had a main drain, so much so that I am strongly considering doing a major renovation next time it needs a new liner, and part of that will be adding a main drain. As to the pump, you might consider getting a 2 speed pump, they are considerably cheaper than the variable speed models.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I like having a drain.
    It always seems to happen that just after I vacuum and put everything away I spot one or two pieces I missed. So I set things to pull from the drain and gently brush the stuff downhill to it, and it gets sucked away.
    Normally I get maybe 30% from the drain. I don't have that temperature stratification some pool have. Low returns would probably accomplish the same thing.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    My pool is a 28 x 14 and we have two main drains, 4 returns, 1 skimmer and two jet spas in the steps. I am glad we got the main drains as they are handy pumping off water when we get a lot of rain. With out a main drain how do you pump out excess water?
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Dec 2010
    San Diego, CA
    1,137
    Quote Originally Posted by Malibu07
    From the skimmer - you never want to drain below the working level of the skimmer anyway
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Both variable speed pumps, and two speed pumps, running on low speed are much quieter than any pump running at full speed.
    Jun 2012
    Austin, TX
    97
    Thanks to everyone for all the info. I don't think I'm going to go with this PB. Another one I met with quoted me all Pentair products with a choice of a 2 speed Whisperflo or a Challenger. I felt like the no main drain wasn't really an "upgrade" anyway.
