Thread: Adding chemicals directly to the skimmer
    austinabrady's Avatar
    May 2012
    Atlanta, GA
    2
    Sure start with 2.4 kg, wait a week, find out where you ended up, and adjust from there if needed.
    I would put the CYA in a sock (or stocking) and put the sock in a skimmer (as long as it doesn't completely block the skimmer).
    I have seen this method of distribution mentioned many times on the forum.
    I was wondering, my pump manual and SWG manual both say NEVER add chemicals directly to the skimmer.
    Could this method be bad for my Intex setup? (it's not a sand filter, it is a filter cartridge type A or C w/skimmer basket)
    Am I better to suspend the sock near the output nozzle?
    Thanks for any advice!
    GAL. = 5725 | Above Ground Intex metal frame 17' x 48" | Cartridge Filter + Skimmer 1500 gal./hr + Intex Crystal Clear SWG | Vinyl | Pool Rover Junior robotic cleaner | Installed on 05/01/2012
    Re: Adding chemicals directly to the skimmer
    CYA is the only chemical that we ever recommend adding to the skimmer, and even then the sock in front of a return jet approach does have some advantages.
    In the Intex manual they are are talking about pouring directly into the skimmer, so the chemicals go directly into the filter. The sock method I mentioned is different, the CYA doesn't actually accumulate in the filter the way it would if you added it directly to the skimmer.
    You can do it either way, but the sock in the skimmer approach is easier and usually dissolves more quickly.
    May 2012
    Atlanta, GA
    2
    Thanks for clearing that up for me!
