Thread: Intex Sand Filter 2650- water inlet nozzel
    So I just got the Intex Sandfilter 2650 up. But the inlet valve (one bringing filtered water back into the pool) is shooting water from the edges. See the pictures below. It has this rubber covering some of the holes, but it looks like it is suppose to stay there but it blocks the outer holes and water comes out the lid edges. So why and what do I do?[attachment=0:19laxuee]poolnoz2.jpg[/attachment:19laxuee][attachment=1:19laxuee]poolnoz.jpg[/attachment:19laxuee]
    Intex 15ft x 48" inch metal frame pool, filled with well water, 637 pump (1000gph)
    Re: Intex Sand Filter 2650- water inlet nozzel
    it is above the water b/c my kids are little and I want them to be able to touch, if wondering
    Also not leaking from the black seal it is from the cover where it is threaded
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Ours did the same thing. No matter how tight I tightened it or tried to tighten it still spit out around the threads just like yours! I could of loved with it if it was shooting out on the bottom as it'd be under water and not trying to pee out over the top rail. So what I did was loosen the outter nut on the outside and rotate the whole assembly so it was on the bottom, tightened up the nut and re-adjusted the eyeball. Not the best answer but it worked. I now don't use that piece as I've added a waterfall fountain as many has done on here and it's not used in the configuration.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Quote Originally Posted by Jamison04
    Is the water suppose to come out on the other holes (not the center one that moves). Did you take the plastic offf covering the holes on the sides?
