Results 1 to 7 of 7
Thread: tf 100 test kit and CH test
    Oct 2010
    michigan
    284
    I have a 15,000 gallon fiberglass pool with spa. (CH 220-320) is what you guys recommened
    I'm currently at 140 CH cause of 2 drain and refills.
    220-320 is a big range, so what should i keep my CH at?
    now the test kits says to add 2 extra drops if there is copper in the water? do I have copper? how much copper? to add 2 extra drops, doesn't all water have copper since it comes from a copper pipe?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    38,449
    Re: tf 100 test kit and CH test
    With a fiberglass pool I think CH is a little less important. Aim for the low end as it will rise as water evaporates.
    If you have not used algaecides or actually have copper pipes in your pool plumbing, your levels should be pretty low. A pool store can test it for you to be sure.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Oct 2010
    michigan
    284
    should be very low copper then, did 2 1/3 drain and refills. all pool plubbing is pvc
    I used to have a 300 gallon reef tank, I have a 12 pound bucket of "high purity calcium chloride anhydrous pellets".
    can i use this to raise my CH in my pool?
    this is food grade as its for REEF fish tank.
    38,449
    Check the Recommended Pool Chemicals article in Pool School, but I think that is the right stuff to raise CH.
    Oct 2010
    michigan
    284
    looks like i could just buy this and be on the safe side, i can get 15lbs for 33 bucks. have a leslie pools local.
    would you guys recommended this to raise the CH?
    http://www.lesliespool.com/Home/Pool-Ch ... 14428.html
    thanks
    38,449
    That should work but I am sure you can find something cheaper at the hardware store ... like the deicer, although probably seasonal.
    Have you calculated how much you need?
    Oct 2010
    michigan
    284
    ya, used the pool calculator, the 15lb bucket would be more than plentiful, 33 bucks not to bad.
    will save bunches of money buying the purifiber over the fiberclear
    also save bunches of money now that i'm pool schooled lol
