Results 1 to 7 of 7
Thread: hot tub folliculitis
    Jul 2009
    Southern California
    23
    So my daughter got a mild case of hot tub folliculitis and the doctor says the spa has to be treated. I called my pool guy who said that the pool and spa already have too much chlorine in the water (he had shocked the pool that week), so there wasn't much else that could be done. Any suggestions? Any additonal things I could do to treat the spa?
    Lloyd
    Salt Water pool shaped like a dog's ear
    WhisperFlo 2Hp, Pentair 4000 series
    Aqua Rite Electronic Chlorine Generator
    Turbo Cell T-Cell 15, Pentax Mini-Max NT
    38,305
    Re: hot tub folliculitis
    We would really need to know what the actual chemistry levels are in the tub before offering thoughts.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Jul 2009
    Southern California
    23
    Yeah, wish I could give them to you. I wouldn't even know how to get you those numbers or which numbers you needed.
    Sorry.
    Thanks for the reply.
    Lloyd
    38,305
    Obviously being a hot tub it is easy enough to replace all the water ... but I do not know what needs to be done to sterilize it.
    Keeping elevated levels of chlorine, relative to the stabilizer if used, will kill everything in it though.
    I would consider getting a test kit to take a little more control of it, but honestly I an not sure what kit/tests to recommend. A FAS-DPD chlorine test is certainly the easiest to be the most accurate.
    38,305
    Oh wait. This is a pool spa combo. Definitely get one of the recommended test kits linked to in my signature. And with a full set of tests we could certainly help you take control of your pool.
    Does your pool guy understand the CYA / FC relationship?
    Reading through pool school ... button at the upper right ... will help you understand your pool and make you better able to ask your pool service better questions at the very least.
    Jul 2009
    Southern California
    23
    Does it make a difference which kit I get if this is a saltwater pool?
    And no, I don't think my pool guy understands the CYA / FC relationship...I don't even know if would know what that is.
    Thanks for the help.
    Lloyd
    38,305
    A SWG pool does not affect the kits we recommend. You may consider adding a test to get your salt level, but that is kind of optional.
    I recommend the TF100 as it has more useful volumes of the reagents you need, but the K2006 is fine as well. The key is the FAS-DPD chlorine test ... you are unlikely to find it locally.
    Please ask any questions that you have and someone is usually around to help quickly.
    Again do yourself a favor and read Pool School. Odds are in less than an hour you may know more than your pool guy
