Results 1 to 11 of 11
Thread: Question for those with in wall skimmers . .even mods
    Ever since putting in an in-wall skimmer (I did hydrotools widemouth mod on intext 16x42). . I am noticing I frequently now have to bleed air out at my intex 2650 pump/sand filter. I do this by slightly unscrewing the lid for the strainer basket on the intex pump until it bleeds out then tighten it back. I am wondering if waves/splashing that goes through the skimmer introduces air. I never had the issue with the standard pool inlet or the above wall intext skimmer. I did put the door on the skimmer that floats the door up when not running but it still swings open and waves make it all the way through the skimmer. Any ideas, suggestions, or advice would be welcome.
    Phil
    24' Round Above Ground, Metal by SOLEX
    Heat Pump, Focus Temp INSTAMAHK 80
    Hayward S-180T Sand Filter
    Hayward Ultra Pro LX Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Question for those with in wall skimmers . .even mods
    Two most common problems with skimmers causing air in the pump, is not having the water level high enough and having the weir door stuck closed(not free floating).
    What is the height of your skimmer opening and where is the water level on it?
    Is your weir door swinging freely?
    Thanks. The door swings freely. My level is now about half way due to splashing and evaporation. I installed it about 3/4 way but water level has fallen. Sounds like I need to add water.
    22,553
    When there's no splashing going on do you still get air in the pump basket?
    Hard to say because the kiddo lives in the pool. I think it may be cause the skimmer is only half way with water.
    When it's running do you have a vortex forming in the skimmer? I did, and it was causing the problem you describe. I made a "vortex breaker" by placing a short piece( 6") of 1" PVC pipe into the skimmer on an angle that prevents the vortex from forming and introducing air into the system.
    Quote Originally Posted by jerallen
    I'm not sure what a vortex looks like. I have seen a little tornado/whirlpool in it. I thought that was normal. Never had a skimmer before.
    38,475
    Quote Originally Posted by PhilGillis
    tornado/whirlpool = vortex.
    There should not be one. Are you able to reduce the flow from the skimmer? if not, you may need to use the trick mentioned above.
    Ok. No way currently to regulate. I'm having a hard time visualizing what you did. Thanks for the help.
    38,475
    Sounds like they just set a piece of pipe in the skimmer basket so that the circular flow can not develop into a vortex.
    22,553
    The basket will normally take care of it but adding something to break the whirlpool may be required.
