Results 1 to 7 of 7
Thread: 20 Mule Team Borax
    May 2012
    Dallas, Texas
    47
    20 Mule Team Borax
    I bought borax and noticed it is sodium tetraborate not sodium carbonate. Did I buy the wrong product/ brand? Should I add it to my pool?
    My levels are:
    FC - 3
    CC - .05
    pH - 7.1
    TA - 80
    CH 90
    CYA - 33
    15,200 gallon 24' X 52" round AG; installed 2011; SWG
    1 hp Dynamo pump; Pentair Meteor sand filter, 2.1 sq. ft. filtration area, 42 GPM flow rate
    TF 100 Test Kit
    Jan 2010
    Randleman,NC
    620
    Re: 20 Mule Team Borax
    Yes,if you are raising PH..
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by kplaster
    ? on water reading's...You need a good test kit to check those reading's yourself..Do not re-ly on pool store result's.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    As kplaster said, borax is recommended to raise ph with just a small bump in TA.
    May 2012
    Dallas, Texas
    47
    I got a Taylor K-2006 in the mail yesterday and check my levels this morning. FC was a low, I brought it up to 3 and headed to the store for Borax.
    TF 100 Test Kit
    May 2012
    Dallas, Texas
    47
    I added approx. 24 oz Borax and 48 oz bleach. My levels are now:
    FC - 3.5
    pH - 7.5
    TA - 90
    TF 100 Test Kit
