Results 1 to 9 of 9
Thread: Ladder attachment issues
    Jun 2011
    Southeast Missouri
    9
    I cannot figure out how to reattach my ladder. It was bolted down but even with a huge washer it didn't work out. The problem is that the places in the ladder for bolting it down are right above the side of the pool. I thought about a small form of decking, but have no way to stabilize it over the pool edge. Any ideas? I just replaced my liner again and don't want it torn. Help!
    24x52 AGP; 1 HP Hayward Power-Flo Matrix;
    Hayward DE Filter Hard Plumbed; BBB Method; Pool School
    🌞 "School's Out For Summer!" 🌴
    Jul 2009
    Olney, MD
    218
    Re: Ladder attachment issues
    Any way you can post a picture of your setup?
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Jun 2011
    Southeast Missouri
    9
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    It looks like the ladder was modified at some point. Did you install the pool or did it come with the house?
    Love TFP? Become a
    TFP Supporter!
    Every confer style (plastic A frame) ladder that I've seen installed has had the main deck at the top of the ladder installed where your's is missing. I believe there is also a deck mount kit available for the A frame's which make things a lot easier. Try searching for your model online and see if one is available.
    Hope that helps
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    Jun 2011
    Southeast Missouri
    9
    We bought the pool new, and this is the ladder that came with it. It has not been altered in any way. I will have to look for the model number harder. I haven't found it on there as of yet.
    This looks like the Integrity ladder (I have one myself), and it does look like the platform is missing (no matter if you have the deck-to-pool model or not). Unless this is some sort of knockoff, but the design details are identical:
    http://www.liverpoolpoolandspa.com/ag-a ... %20LADDERS
    Jun 2011
    Southeast Missouri
    9
    Here are a few more shots of the ladder.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I have the same ladder and I am looking to convert my ladder to work the way you have it. I am currently using it as an A-Frame ladder and I am going to convert it to a deck ladder. When used as an a-Frame, this ladder has a plastic platform between the two side handles, a ladder that attaches to the platform and two legs with a footing. Here is the owners manual I found a LINK to.
    I went and talked with the LPS that sold it to me and asked what I needed to do to convert it. She said, if the deck is lower than the edge of the pool, you need to build up the deck to the bottom of the handles and then mount them to the deck using the holes provided. I am going to use the largest washer I can get in the hole.
    As for your situation, does the ladder fit in the pool without rubbing on the side wall and do the existing bolts line up with the slot/hole? (see page 8 in the link)
    Do you have any ballast in the solid section at the bottom of the last step. My ladder wanted to float too much without bricks inside. (see step 1 in the linked file).
    Looking at your photo
    IMG_20120602_153023 by dagdouglas, on Flickr, I am going to do something similar but have it support the entire handle section.
    -- Guy --
