Thread: CH Test
    Mar 2011
    Grand Rapids, Michigan
    279
    CH Test
    Hey guys & gals. Need your help & advice on my CH test. I either have none or my reagent is old/ineffective. Bought my TF100XL last year and still using same reagents and all seem to be fine. When I add the R-0011L the sample does not turn red. Not even a hint of red. The drops are almost an oily yellow. But since I want to help keep Duraleigh in business I figured I do the test twice and add the R-0012 anyway. I don't believe I have any copper present because I have city water. Never worried so much about CH because of a vinyl liner. Now I'm kinda worried. D'OH! Any thoughts out there? Test results as of 10 minutes ago are FC 10/CC 0/Ph 7.2/ALK 110. Will be adding Borax to boost Ph. Will also be ordering reagents soon, too!
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Re: CH Test
    The dye, R-0011L is an organic dye used to provide the red/blue color. It should be a deep blue color before it enters the sample. If the dye stains the plastic bottle it is stored in or is no longer a deep blue (before use), it has gone bad.
    Mar 2011
    279
    Re: CH Test
    Thanks abunch Jason. The reagent is a brownish red. Certainly not blue! Time to take an inventory & order some reagents. Thanks again.
    30,432
    Re: CH Test
    Debbie,
    Check your PM's
    Mar 2011
    279
    Re: CH Test
    Will do. And Jason, forgot to say thanks for the quick service! Another great reason to stay out of the pool store!
