Thread: Epoxy Paint Popped
    Epoxy Paint Popped
    Hi to all;
    Pool was epoxy painted earlier this year and a small piece (2") has popped off. Hope this is not a sign of things to come!
    Is there any way to repair this spot without lowering pool level?
    Thanks for any help.
    Regards,
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Re: Epoxy Paint Popped
    No, there isn't any useful way to repair with water covering the affected area. Repair might not be all that important, depending on what is under the paint.
    This is one of the big reasons we don't ever recommend painting a pool. Paint doesn't last that long, and when it starts to fail it looks terrible.
    Many thanks for the reply!
    It's only been about a 1-1/2 months since it was painted. I had hoped it would last a few years at least.
    I'm going to try some underwater patch and see if it will work.
    Regards,
    Gary R.
    Just to follow up:
    Aplied waterproof cement patch to the spot where the paint popped. It set up fine and seems solid. Looks like they had painted over a loose chip and it came off when I vacuumed.
    All's well for now.
    Gary R.
