Thread: PH decreaser
    Apr 2012
    South Dakota
    87
    PH decreaser
    How long does a treatment typically take before you can see results? 8hrs or one turn over?
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    Re: PH decreaser
    Muriatic acid (a liquid) mixes i especially quickly, so you can retest the PH after half an hour as long as the pump has been running. Dry acid (usually powdered) takes a bit longer, so give it an hour with the pump running before retesting.
