Thread: Replacing skimmer on AGP
    Hi all. I have a 24' x 52 AGP. It was actually a Jacuzzi brand, which is of course now defunct. The wide mouth skimmer is cracked, not leaking *yet* but I'd like to replace it. If I drain the water to just below the skimmer, will the liner stay in place for me when I remove the screws? Also, since Jacuzzi is no more, the pool stores have Hayward skimmers. Are the hole placements pretty much standard on these so the screws line up? And do you guys recommend coating the new rubber gasket with NSF grade silicone grease?
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    22,608
    Re: Replacing skimmer on AGP
    I would measure both of them carefully to make sure they are the same.
